No aplicable
07-03-2021
09:02 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
When I type 'PO' and press enter, I can only select one point and then AutoCAD exits the command without any Esc or Enter key pressed by me
In contrast when I select the Multiple Points in the expanded Draw panel, I can select as many points I want and then I can exit the command by pressing Esc key
Is there a system variable that causes this difference between PO and Multiple Points? How can I make PO command work like the Multiple Points?
¡Resuelto! Ir a solución.
