Diesel Expression (automated sheet numbers)
I am trying to design a Diesel Expression to insert the Revision letter for each sheet of the drawing by fetching it from the layout tab at the bottom of the drawing window (P.S.- I am using AutoCAD 2015).  How can I access the information in these tabs?
msanford.ail
You could use a field to populate the revision based on the tab contents
That is actually exactly what I'm trying to do. The problem is that I don't know how to reference the tab name in the Diesel Expression.
Andy Tannen (US)
Sr. Electrical Engineer
[Capture]
INSPIRED WORK
23535 Cottonwood Parkway
California, Maryland 20619
(301) 862-7252
andrew.tannen@baesystems.com
Andy Tannen (US)
[Capture]
INSPIRED WORK
(301) 862-7252
rkmcswain
$(getvar, ctab)
Add a field in a text
$(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),1),2)
This case will use the last digits from de tab name.
