Noob Question about Extrude
Hello, Sorry for this noob question, but im really new to AutoCad
I use version AutoCAD2017 and have the following problem:
When i use a standard shape from the "DRAW" section like rectangle, circle or hexgon, i can draw that and then extrude it to a "block", if i draw a own shape with the line tool, and press extrude, i can only extrude the line it self. If i extrude all lines the object will be empty. How can i extrude own objects.
See attached an image, the cylinder is a extruded circle, and the other thing does not work 😞
Pleas help me!
Patchy
Use PRESSPULL command
or you have to Pedit and multiple Join the entities before Extrude.
or make BOUNDARY, REGION from them, then you'll have 3d SOLID.
Thank you! Pedit&Join worked perfectly! :)!!! THANKS
