Part fitting as good as possible
Im working in a company where we cut a gasket sheets to a different size and shape gaskets. (For example, 10 circles OD 220mm ID 150mm, 5 squares with bolt holes, dimensions 300 mm x 300mm, 5 circles OD 820mm x 700mm).
Is there some tool around which would automatically fit different size and shape gaskets in to that sheet size (1500 mm x 1500 mm), to be as efficient as possible (to minimize leftovers/trash).
Let me know
pendean
Community Legend
Community Legend
Which exact Autodesk software are you using?
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
There is nothing native in AutoCAD that does this. I did find this plugin on the Autodesk App Store that might be worth investigating.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Hello John,
That plugin was exactly what I was looking for.
Thanks you for help.
john.vellek
Hi @Anonymous,
I'm glad that I could help out. Let me know how the utility performs. Perhaps make a Screencast if you have time. I would like to know how well it works for this process.
John Vellek
