AutoCAD Forum
DGNPURGE eNullObjectld
11 REPLIES 11
Message 1 of 12
KMSL_INTT
2456 Views, 11 Replies
Hotfix DGNPURGE doesn't work in all files.
The command starts but can't fix the problem.
eNullObjectld message appears.
I've already tried audit, recover, dxfout-dxfin and nothing has worked.
Is there a solution for it?
11 REPLIES 11
Message 2 of 12
braudpat
in reply to: KMSL_INTT
Hello
Welcome to the Autodesk/AutoCAD Forums !
Can you share with us your DWG (in ZIP format please) ?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 12
KMSL_INTT
in reply to: braudpat
Hello!
Thanks!
Here is the file!
Message 4 of 12
braudpat
Hello
It seems that they are some AEC objects into your DWG !?
Are you using : CIVIL, AA, MEP ? ... If YES, which version exactly ?
So I have purged & cleaned up (Maybe a little bit too much) your DWG !
So please test it ...
Patrice BRAUD
Message 5 of 12
KMSL_INTT
How did you clean it? It's clean and perfect now!
I couldn't use purge, neither DGNPURGE.
I work in an engeneering company, so I received this file from another person.
We use Civil 3D too, that may be used in this drawing. Version 2012.
Sorry if my English it's not the best, it's been a while I don't practice it.
Message 6 of 12
braudpat
Hello from France
I have used ACAD 2015 and its NEW PURGE command (which has special tricks to purge DGN LineTypes) and then some special tools ...
Please check that I haven't destroy any specific CIVIL 2012 Infos / Objects !!
Have a nice WE, Regards, Patrice
Patrice BRAUD
Message 7 of 12
KMSL_INTT
Well, thank you!
But I'm afraid that may exist more drawings with the same issue and we don't have autocad 2015.
Do you know another way to solve this DGN problem?
Message 8 of 12
braudpat
Hello from France
I see one temporary solution !
Well maybe you can download an ACAD LT 2015 and it will run for 30 days ...
Please install it on a 4 Gb Ram PC with a Win 32 or 64 bits
So you have ONE month to purge your bad DWGs !?
It's a French Idea !
How many DWGs ?
Patrice BRAUD
Message 9 of 12
KMSL_INTT
I appreciate, thank you.
I can do that until we don't upgrade our licenses.
Message 10 of 12
braudpat
Hello
If I read well, you have a CIVIL 2012 (or maybe an ACAD 2012) so you could try DGN-PURGE from ajilalv (ajilalv@gmail.com)
This utility is compatible with :
    Autodesk AutoCAD - Version: 2015 , 2014 , 2013 , 2012
    Autodesk AutoCAD Architecture - Version: 2015 , 2014 , 2013
    Autodesk AutoCAD Civil 3D - Version: 2015 , 2014 , 2013
So you have a chance !?
On Google, please search with these words:  dgn-purge  ajilalv
and you will find it !
Please let us know ...
Patrice BRAUD
Message 11 of 12
Welcome,
I have a problem with purging DGN lines in my autocad 2013 LT. I am not able to read in DGNPURGE dedicated for full version of autocad. Can you please send me DGNPURGE command for autocad 2013 LT?
thanks
Regards
Jaroslaw
Tags (1)
Message 12 of 12
KMSL_INTT
AutoCAD Inside the Factory
