Hotfix DGNPURGE doesn't work in all files.
The command starts but can't fix the problem.
eNullObjectld message appears.
I've already tried audit, recover, dxfout-dxfin and nothing has worked.
Is there a solution for it?
Solved by braudpat. Go to Solution.
Hello
Welcome to the Autodesk/AutoCAD Forums !
Can you share with us your DWG (in ZIP format please) ?
Patrice BRAUD
Hello
It seems that they are some AEC objects into your DWG !?
Are you using : CIVIL, AA, MEP ? ... If YES, which version exactly ?
So I have purged & cleaned up (Maybe a little bit too much) your DWG !
So please test it ...
Patrice BRAUD
How did you clean it? It's clean and perfect now!
I couldn't use purge, neither DGNPURGE.
I work in an engeneering company, so I received this file from another person.
We use Civil 3D too, that may be used in this drawing. Version 2012.
Sorry if my English it's not the best, it's been a while I don't practice it.
Hello from France
I have used ACAD 2015 and its NEW PURGE command (which has special tricks to purge DGN LineTypes) and then some special tools ...
Please check that I haven't destroy any specific CIVIL 2012 Infos / Objects !!
Have a nice WE, Regards, Patrice
Patrice BRAUD
Well, thank you!
But I'm afraid that may exist more drawings with the same issue and we don't have autocad 2015.
Do you know another way to solve this DGN problem?
Hello from France
I see one temporary solution !
Well maybe you can download an ACAD LT 2015 and it will run for 30 days ...
Please install it on a 4 Gb Ram PC with a Win 32 or 64 bits
So you have ONE month to purge your bad DWGs !?
It's a French Idea !
How many DWGs ?
Patrice BRAUD
Hello
If I read well, you have a CIVIL 2012 (or maybe an ACAD 2012) so you could try DGN-PURGE from ajilalv (ajilalv@gmail.com)
This utility is compatible with :
Autodesk AutoCAD - Version: 2015 , 2014 , 2013 , 2012
Autodesk AutoCAD Architecture - Version: 2015 , 2014 , 2013
Autodesk AutoCAD Civil 3D - Version: 2015 , 2014 , 2013
So you have a chance !?
On Google, please search with these words: dgn-purge ajilalv
and you will find it !
Please let us know ...
Patrice BRAUD
