AutoCAD Forum
Deselecting by Shift+Click Stopped Working?
20 REPLIES 20
Message 1 of 21
50576 Views, 20 Replies
A while ago I found out you can deselect something from your current selection set by holding down the shift key and clicking on it. This was a pretty useful tool...but then it randomly stopped working today for me. Any ideas as to why this might have happened?
20 REPLIES 20
Message 2 of 21
Alfred.NESWADBA
Alfred.NESWADBA
verify the PICKADD variable, is it set to 2 or another value.
Also interesting might be if you have Map3D or Civil3D, because then you have a command _MAPIOPTIONS and in the dialog ==> 2nd tab you also have a option for how <Shift><Click> works.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
Message 3 of 21
in reply to: Alfred.NESWADBA
Checked the PICKADD variable--it was set to 1 and I changed it to 2, which didn't solve the problem.
I actually am using Civil 3D and I tried pulling up that dialog but I can't find the option you're talking about. What are the texts for the tab and for the option?
Message 4 of 21
rkmcswain
rkmcswain
See if one of these is perhaps the problem.
http://cadpanacea.com/node/14
http://cadpanacea.com/node/230
R.K. McSwain     | CADpanacea | on twitter
Message 5 of 21
in reply to: rkmcswain
Thanks rkmcswain! It turned out changing things in MAPIOPTIONS (which is different from MAPOPTIONS, which is what I mistakenly read the command Alfred posted as, which explains my previous confusion, BTW) didn't do anything to help, but turning the "Shift+Left click image select" option off in IOPTIONS did the trick for me.
Message 6 of 21
patpat79
patpat79
It is indeed the IOPTIONS.... well that works for me...
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
Best Regards,
Pat Andres
GHD Manila
Message 7 of 21
This worked for me too! Thanks
Message 8 of 21
Worked for me too, with the caveat that the command is now "IOPTIONS" and not "MAPIOPTIONS." Thanks for the help, rkmcswain!
Message 9 of 21
rkmcswain
rkmcswain
@Anonymous  - when I type in IOPTIONS, the command line changes it to MAPIOPTIONS, which is still documented.
Message 10 of 21
Alfred.NESWADBA
Alfred.NESWADBA
Do you have RasterDesign installed?
- alfred -
Alfred NESWADBA
- alfred -
Alfred NESWADBA
Message 11 of 21
this fixed the issue for me in civil3D
thank you!
thank you!
Message 12 of 21
FilipBednarski
FilipBednarski
Helped me in 2021 (AutoCAD 2017). Thanks!
Message 13 of 21
cadffm
cadffm
No rasterdesign installed?
Is it the case also with a simple line object?
https://forums.autodesk.com/t5/autocad-forum/autocad-2015-can-not-shift-click-to-deselect-a-solid-su...
Sebastian
Sebastian
Message 14 of 21
dain.synhorst
in reply to: cadffm
dain.synhorst
Community Visitor
Community Visitor
I have rasterdesign, but I had run both IOPTIONS and MAPIOPTIONS to get this to work. When just doing one or the other commands shift-click-delsect still does not work. In other sense I had unselect Shift+Left Click Image Select in IOPTIONS and MAPIOPTIONS. (Civil 3D 2022)
Message 15 of 21
safavi_maryam
safavi_maryam
Community Visitor
Community Visitor
Worked for me too
Worked for me too
Message 16 of 21
Frank_EganVKZC5
Community Visitor
Community Visitor
I have raster and tried the IOPTIONS and it didn't work.
Message 17 of 21
Amy.taylor
Amy.taylor
Currently working in AutoCAD 2023, with Raster Design installed. C3D 2023 installed but not open.
IOPTIONS works for me (Raster Design perhaps?), but MAPIOPTIONS does not (Civil 3D perhaps?).
Either way, I'm glad for this post.
Message 18 of 21
jbraddy2
jbraddy2
Community Visitor
Community Visitor
deselecting it in "ioptions worked for me" but deselecting it from "mapioptions" did not. Thanks for clerifying the difference!
Message 19 of 21
ThreadRed
ThreadRed
I just had the same issue. I found out that I had an image on a turned off layer that's causing issues with deselecting objects.
Message 20 of 21
jchristiansenMAY4G
jchristiansenMAY4G
Thank you for this. I tried the MAPIOPTION and it didn't work. Using just IOPTION, it worked.
AutoCAD Inside the Factory
