AutoCAD Forum
Deleting extrude without losing sketch
4 REPLIES 4
5263 Views, 4 Replies
Hi, when I'm deleting an extrude I lose my sketch which the extrude is made from. How do I delete the extrude without touching the sketch?
Kind regards
Joakim
4 REPLIES 4
Alfred.NESWADBA
You can use/activate SELECTIONCYCLING (>>>details<<<) so you get a popup for all objects under the cursor position to choose which object you want to select.
But let's see another systemvariable: DELOBJ (>>>details<<<) ... maybe the base object for extrusion already is deleted after you created and extrusion from it 😉
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
StephenThomasGrace
You may want to try PRESSPULL instead of EXTRUDE.
It leaves the sketch entities behind.
-steve
dbroad
For the future consider taking advantage of the delobj setting options.
Architect, Registered NC, VA, SC, & GA.
parkr4st
in reply to: dbroad
once you delete and realize the error   CTRL Z and put the extrusion back, CTRL Z again and undo the extrusion
or eXplode the extrusion once, and then you can delete individual surfaces and not the entire object.
Then set the delobj and proceed properly
AutoCAD Inside the Factory
