After installing Autcad 2018.1.1 after some object copy commands, the dynamic input bar remains active, I have to get close to any object and wait for the properties to be seen to delete the dynamic input bar
If I uninstall update the dynamic Input command does not show up, everything works perfectly.
Actually it is the update of AUTCAD 2018, which is the basis that creates the problem then in Arch. Where I installed update 2018.0.3.
This problem did not happen with the update of AutoCAD 2018.1, only with 2018.1.1, the problem is that I no longer find the update 2018.1 of AutoCAD in the list of possible updates
So che sono separati ma la base è l'unica autocad2018 ... provo a riparare l'installazione di 2018.0.3 Forse risolve il problema.
This problem affects all extensions that use autocad2018, see Advancesteel 2018
Perfect, now we both match.
Does REGEN or REGENALL commands remove the stuck dynamic input image from your screen?
Does clicking over to the START tab, counting to 10, then back clear it?
Does clicking on a layout tab, then back to model clear it?
Start GRAPHICSCONFIG command, on that pop-up, under hardware setup, are you running DIRECTX11? If you turn oiff Hardware Acceleration on that pop-up, does the problem go away?
Which video card are you using? Does it have updated drivers you can install?
In the meantime, this appears to be a known problem for a few users with no fix yet https://forums.autodesk.com/t5/autocad-architecture-forum/aca-2018-dynamic-input-prompt-does-not-ref...
start GRAPHICSCONFIG command, on that pop-up, under hardware setup, are you running DIRECTX11? If you turn oiff Hardware Acceleration on that pop-up, does the problem go away?
Quadro K4200,
