AutoCAD Forum
Delete Group Text
7 REPLIES 7
Message 1 of 8
572 Views, 7 Replies
Delete Group Text
Can I use Find to delete a a bunch of text at once instead of just replacing text? What is best way to remove text that has been use many times in a drawing such as "provide".
7 REPLIES 7
Message 2 of 8
pendean
If you want to replace a word with another or just a blank space, FIND is indeed the tool to use.
Message 3 of 8
rkmcswain
Also in the future, consider using a block as a container for this "bunch of text" that is all the same. Then you can simply update the block definition and everything will change at once.
R.K. McSwain     | CADpanacea | on twitter
Message 4 of 8
Patchy
in reply to: pendean
Replace with a blank space, would that make a double space between 2 words?
Message 5 of 8
pendean
in reply to: Patchy
I meant blank, no space needed unless you want to add one.
Message 6 of 8
Patchy
I try to replace a word with no blank space, it didn't do anything.
Maybe I need to upgrade.
Message 7 of 8
pendean
in reply to: Patchy
I've been doing that this week in R2016 for some reason in a bunch of files from an outside source, so my experience is only there. I can't recall having to do it any differently with older versions but I can't swear to it, it's rare for me to delete one word in many text items in a file(s).
Message 8 of 8
scot-65
in reply to: Patchy
Just as Pendean suggested - use FIND.
Replace "provide " with " ".
Notice the blank spaces...
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Forma Design Contest
