DbConnect to SQL server
valdemiro.mendes
valdemiro.mendes
Hi folks,
we just migrated from SQL Server 2019 to SQL Server 2022 and since then I can't connect do my Databases with DbConnect.
The UDL file is unchanged except for "Data Source=[NEW SERVER NAME]".
AutoCAD 2025 crashes whenever I try to connect to a database (see attached video).
Sometime the connection succeeds but crashes when I disconnect.
As you can see in the UDL file, there is nothing special in it.
Any ideas?
System:
Windows 11 Enterprise (10.0.26100 Build 26100)
Autocad 2025.1.1 (Product ver. V.154.0.0)
pendean
Community Legend
Community Legend
AutoCAD 2025.1.2 is the latest, while you wait... .
valdemiro.mendes
well, not exactly the answer I expected, but I'll give a try... 🙂
pendean
Community Legend
Community Legend
It was not an answer exactly, just a friendly reminder your software is not current and everyone trying to help you with your SQL crashing issue is going to want you to get there first. So you might as well do that.
Don't forget to restart your PC afterwards.
Izhar_Azati
Apparently no one else in the world, except you and me, is trying to work with the tool that started back in DOS.
Every time the software crashes, I send the report and no response.
pendean
Community Legend
Community Legend
@Izhar_Azati wrote:
...Every time the software crashes, I send the report and no response.
There is never a response to you from Autodesk, ever, unless there is a known fix then a prompt will appear linking you to it assuming your firewall/network is not blocking that.
TheCADnoob
Does it consistently connect when you test the connection?
CADnoob
