AutoCAD Forum
Datalinks imported with blocks
1 REPLY 1
mbuettner3ZZXT
191 Views, 1 Reply
I created a file that had 100+ datalinks in it.
When I opened a different file and got a unlocatable references warning I discovered this new file had all 100+ datalinks (broken) included in the Xref.
What I discovered is that importing a block (any block) from the file with the datalinks attaches all the datalinks to the new file. So the couple of blocks I put in my favorites list have contaminated any file I've used them in.
Is this normal block/datalink behavior?
(the datalinks are all to tables in the original files, none of the blocks in question utilize any datalinks)
1 REPLY 1
It doesn't seem normal.
Run this at the command line then save, close and reopen the file.
(dictremove (namedobjdict) "ACAD_DATALINK")
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Forma Design Contest
AutoCAD Beta
