Hello All,
Background:
I have a table in AutoCAD 2013. I got it by pasting from Excel using PASTSPEC AutoCAD Entities, then I stripped all the formatting using StripMtext v5-0b.lsp. I have table breaks manually positioned and only changed column width, row height, text size, etc.
Problem:
When I edit a cell and move to the next or click out of the table it takes 2-5 seconds to update the table. This can be very tedious when editing many cells.
I've tried turning off table breaks and doesn't seem to make a difference. I made a new table in AutoCAD larger and populated it and have table breaks on manually positioned as a test. It also takes some time to update. Is there a setting maybe to turn off that I don't need that's causing it to take a while to update?
Any help is appreciated.
Thank you
Thank you for the response!
I'm on a dell latitude ultrabook with win7. File size is 8 MB. The table is not linked to Excel. The rest of CAD works just fine and nothing freezes it up except the table, and only when editing it, not just drawing it. It still does it in a brand new blank file with an AutoCAD generated table not pasted in from elsewhere. It has to do with the table breaks and having the "Reapeat top lables" set to "yes".
I've attached a brand new AutoCAD file and if you edit one of the cells and move on to another, it will take about 5 seconds to process.
Breaking up a sinle table as you have done does force AutoCAD to work a lot harder. IMHO those probably ought to be 4 separate tables if you want zippier performance.
having said that, I edited the cell you see in your file (attached) in about 10-seconds total on my 3-year old PC running R2016 on Win7 64bit. There is nothing slow about your sample file here.
Thank you,
You are correct; after further exploration, the "vanilla" AutoCAD table worked fine this time in the example file attached previously, as you stated. I exported the table to a .csv file and then opened and pasted from Excel back into AutoCAD using PASTESPEC and selecting AutoCAD entities. This table started slowing down once I set up table breaks and really slowed down when I selected repeat top rows.
So, there must be some formatting setting or some setting in the background from the pasted AutoCAD entities that is causing the lag compared to the "vanilla" AutoCAD table. I've attached the updated version with both tables mentioned. When editing the left table it is fast, but when editing the right table with black text it is very slow.
The STRIPMTEXT didn't seem to make a difference either way on either table and was just to get rid of the black text.
If it were just a second between edits it wouln't be a big deal but 5 seconds is a long time when editing 10 or more cells one by one. There may not be a solution to this but I hope there is.
Hello!
I also have the same problem of data entry into table very slow to update. The only way for me to solve is as you said, closing and reopening. I have a large amount of data to entry into table and so I am having to make several times for closing and reopening. So if you now have another way to solve this problem, please provide.
Thanks and best regards.
Kyaw Zin Thant.
Found a solution for this. Just hit AU Space space. That's Audit, with NO for fixing errors, it comes back to normal immediately.
You are a life saver! I imported a very large excel table and every time i needed to make a change, even to just one cell, it would take over a minute to complete the process. After running the audit command everything works perfectly again. Thanks!
Thank you, that one simply works! What is funny, I run audit before the final safe. After inserting the Excel linked table I have to run again :). Autodesk, pay attention!
