Message 1 of 10
09:29 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm recreating elements of a drawing, one of which is a drainage run, the original drawing uses a line type that is a dashed line that appears thick & is square at the ends. I assumed that was done by using line weight, however at the end of each dash the end appears round not square, I've attached a picture of them both for you to see (attached).
