Dashed Line appearing rounded, not square
Message 1 of 10
I'm recreating elements of a drawing, one of which is a drainage run, the original drawing uses a line type that is a dashed line that appears thick & is square at the ends. I assumed that was done by using line weight, however at the end of each dash the end appears round not square, I've attached a picture of them both for you to see (attached).
Replies (9)
Message 2 of 10
the problem could be in your ctb file, adjust the line end style under the properties section.
Message 3 of 10
imadHabash
can you attache a CAD dwg file for the lines appears round not square ?
Imad Habash
Message 4 of 10
vinodkl
The dashed line is assigned a global width and not line weight. Line's with line weight will have a rounded edge🙂. I hope this clarifies your doubt.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 10
Can anyone please let me know if you are able to adjust the "global width" in CAD lite? If so, where/how? Thank you!
Message 6 of 10
Kent1Cooper
That is a characteristic of Polylines only [see the Properties palette], so anything you want to have that would need to be one or be converted into one.
Kent Cooper, AIA
Message 7 of 10
The lines I'm referencing are Polylines, they are dashed like the other posters example, but like theirs the ends of each of the dashes are rounded.  I'm trying to figure out how to stop them from being rounded.
Message 8 of 10
Kent1Cooper
What global width do they have [pick one and look at its Properties]?  If it's zero, that is probably the cause -- change it to a non-zero value and don't use lineweight.
Kent Cooper, AIA
Message 9 of 10
Thank you! For some reason ONE line that I had selected wasn't a polyline so I wasn't seeing where to change the global width but now that I've corrected that I've gotten it updated and that works perfect.  Thank you for explaining!
Message 10 of 10
peterl39TFV
Observer
Observer
YES. Specifically:
Plot dialog window -> ctb properties popup -> table view -> set the first color to “Butt”, right-click ‘line end style’ -> apply to all styles
