AutoCAD Forum
Customise properties tool palette
1 REPLY 1
M_c3d
292 Views, 1 Reply
Hoping for some assistance.
Is it possible to edit the properties tool palette?
If yes, where is it found under the cui?  I can't seem to find it in there.
This is a civil 3d question but more relates to autocad customisation than civil 3d, the plan is to add another command under the data section of the attached tools palette.
1 REPLY 1
john.vellek
in reply to: M_c3d
Hi @M_c3d,
Interesting question! I don't believe you can modify the properties interface anymore than you could the Layer Manager. You might try posting in the customization forum to see if anyone has a solution that would help you.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
AutoCAD Inside the Factory
