AutoCAD Forum
Custom pull down menu
1 REPLY 1
245 Views, 1 Reply
I am trying to install a pull down menu from a third party. I received a .mnu file along with a few hundred dwg files. I added the new menu.cuix through the customize user interface and the menu appears in my pull down menus, but it is not referencing back to the dwg files I received. I added the location of the dwg files to the support file search path, but that didn't allow access. Any guidance would be most appreciated.
1 REPLY 1
pendean
The specific menu sections may be hardcoded to look for the DWG files at a very specific place: look further, in more detail, and find out.
To test whther the location of those DWG files is easily available to AutoCAD, test at the comamndline by typing -INSERT (there is a dash in the name, then hit <enter> then just type the name of one of those blocks and hit <enter> again. If AutoCAD finds it, will will not complain.
Forma Design Contest
AutoCAD Beta
