Curve and repeat an item on a path
Message 1 of 18
I'm trying to create a curved stage: I've a straight trellis and I would like to curve it on a path (I've tried with the Sweep item but it doesn't work). How can I do?
See the screen: Schermata 2020-12-02 alle 14.34.30.png
Replies (17)
Message 2 of 18
Patchy
Don't sweep along a tube, it doesn't work that way. You use sweep along a single edge (Arc, Polyline, Line....)
If you want it to repeat, use measure command.
You mean like this?
Message 3 of 18
no I mean like a unique curved element. So I don't want the space between the trellis
Message 4 of 18
Patchy
That was an example, you know how to use measure command right?
Message 5 of 18
I'm trying to do that but I don't know how to use it.. Can you help me??
Thanks...
Message 6 of 18
Patchy
Make a block out of it and use measure with a block.
Message 7 of 18
Can you do that with my dwg project? I didn't understand...
Message 8 of 18
Patchy
Save it down to 2007 format for me, I don't have new Autocad.
Message 9 of 18
Try this.. thanks in advice bro
Message 10 of 18
Patchy
Message 11 of 18
I can't find the curved line in your file. I think I've uploaded the wrong file, can you try with this? Sorry for the trouble...
Message 12 of 18
Patchy
Message 13 of 18
I can't find the curved trellis. Is that normal? Schermata 2020-12-02 alle 22.03.16.png
Message 14 of 18
Patchy
Then you have to draw the trellis with arcs to make it curve.
Chop up your sweep path and draw on it.
Message 15 of 18
No bro, I can't understand that. I don't know how to make a curved trellis. I think that the command measure was working but it create the curved trellis on another part of the draw.
Message 16 of 18
This was perfect. Where can I find it? How can I make the lines a bit more bigger (I used a circle of 0.050) and sweeped all the lines.
Message 17 of 18
Patchy
Message 18 of 18
Patchy
You can draw a curve trellis too and Polar Array it.
