Cursor Lags
Cursor Lags
stefano7ZPLL
Message 1 of 52
Cursor Lags
stefano7ZPLL
Hi everyone,
I am using AutoCAD 2022 and I have this annoying problem, my cursor, when it is in the model space, it starts lagging. It happens only when I am in the model space. I checked online and someone said "turn off Hardware Acceleration", it worked but I needed to use the point cloud, so it is not a good choice for me.  I deactivate some feature suggested in this forum, it didn't work. I updated my graphic card and nothing.
there is a way to use the point cloud without the mouse lag? I almost try everything I read on this forum, but nothing works. Until yesterday I used 2021 and I never had this problem.
Thank You
Stefano
This is the Turner Log:
Card name: NVIDIA GeForce GTX 1050
Driver version: 27.21.14.6192
Tuning Date:
Virtual device: Dx12 (Hardware)
The card and driver meets the recommended requirement.
Display Adapters:
Intel(R) UHD Graphics 630(Primary)
Certification:
Feature Mode kFM_Advanced
Feature Mode Available 120
Hardware Available True
Hardware Recommended True
Status 5
Hardware ID 3
Hardware Feature Level 51
Software Feature Level 50
General Options:
Adaptive Degradation True
Discard Backfaces True
Dynamic Tessellation True
Generate Vertex Normals False
Handedness Right
Maximum LODs 6
Redraw on Window Expose True
Surface Tessellation Tolerance 92
Transparency MediumQuality
Processor
MaxClockSpeed 2201
Name Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
NumberOfCores 6
NumberOfLogicalProcessors 12
Replies (51)
Message 41 of 52
gorjan_sw
Community Visitor
Community Visitor
life saver!!!
Message 42 of 52
marclen.eleccion
Community Visitor
Community Visitor
Thank you!
Message 43 of 52
ParishSouthBdx
FOR SOME REASON, when I have this issue, i double click a block, this opens the block editor and i immediately close it. Seems it releases some captive memory i'm guessing. I'm thinking this would be an alternate solution to someone who may have the same issue as I have.
Message 44 of 52
EnM4st3r
to add to this topic, i also noticed a similar problem on my system. However it is a bit more weird, the cursor was only stuttering if i had my AutoCAD on Fullscreen (not the AutoCAD fullscreen (ctrl+0) but the windows fullscreen), in windowed mode the stuttering was gone. Also the cursor was only stuttering on one of my Monitors on the other one it was fine. Very weird..
For me switching to GFXDX12 - 0 also resolved the issue
Message 45 of 52
mlachanceQHNAT
'CURSORTYPE=1' (mousepointer) solved this issue for me (Civil2023)
The lagging skipping freezing stuttering cursor issue was only while IN a command (ANY command) but before the first click for the command's start point (example RECT, Circle, Line, etc., etc.)   Problem just started a week ago, and nothing has fiixed this except the Cursortype solution. (DX12 > 11 had no effect, Snap/grid mode, while appearing similar, was not the issue)...
Out of curiosity, i tried CURSORTYPE=0 (crosshair) with CURSORSIZE decreased from 5 to 3 and while the problem was still present it was noticeably improved. But the only way ive found to completely fix this is CURSORTYPE=1 (mousepointer)
Message 46 of 52
sjorda3
Community Visitor
Community Visitor
solve my problem in cad 2025 . thanks
Message 47 of 52
ParishSouthBdx
post withdrawn
Message 48 of 52
engineerG2T7H
Community Visitor
Community Visitor
Thank you. this worked for me.
Message 49 of 52
ParishSouthBdx
Could be the 2.20GHz you're firing with.  h a....just joshin.
Message 50 of 52
foranj93RSQ
I just fought with this little annoyance to no avail with all options given here. However I did find a remedy. Call the "UCSDETECT" command and set it's value to zero. This fixed my problem immediately... found on reddit mind you so I figure this would be a better home for that information.
Message 51 of 52
ng.the.nhan96
Community Visitor
Community Visitor
sir you save my life, thanks so much.
Message 52 of 52
igi_pop
Since I had this issue of laggy panning, mouse moving, ect, and i seem to have solved it, I thought I'd chime in.
Since I'm working in C3D21, there is no option to switch from DX12->DX11 since it's already DX11.
None of the other options suggested here changed a thing.
I have a solid machine, everything is in my sig, so this kind of behaviour is just...doesn't make sense.
HOWever, i did manage to upgrade the behaviour:
1. windows graphics options - add the autocad.exe to the list, and set it to "high performance"
2. use your board and cpu management apps, and lift the cooling fans profiles to a higher speed and noise. that way it'll stay cooler (obviously) in the moments where you need more power. instead of waiting for adjustments when the power draw occurs. I've done so for my card, and whole case+cpu. And performance drops - dropped 🙂 just a bit more consistanat behaviour.
That's my 5c for tonight.
Cheers,
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
