Cursor Lags
Cursor Lags
stefano7ZPLL
Message 1 of 52
Cursor Lags
stefano7ZPLL
Hi everyone,
I am using AutoCAD 2022 and I have this annoying problem, my cursor, when it is in the model space, it starts lagging. It happens only when I am in the model space. I checked online and someone said "turn off Hardware Acceleration", it worked but I needed to use the point cloud, so it is not a good choice for me.  I deactivate some feature suggested in this forum, it didn't work. I updated my graphic card and nothing.
there is a way to use the point cloud without the mouse lag? I almost try everything I read on this forum, but nothing works. Until yesterday I used 2021 and I never had this problem.
Thank You
Stefano
This is the Turner Log:
Card name: NVIDIA GeForce GTX 1050
Driver version: 27.21.14.6192
Tuning Date:
Virtual device: Dx12 (Hardware)
The card and driver meets the recommended requirement.
Display Adapters:
Intel(R) UHD Graphics 630(Primary)
Certification:
Feature Mode kFM_Advanced
Feature Mode Available 120
Hardware Available True
Hardware Recommended True
Status 5
Hardware ID 3
Hardware Feature Level 51
Software Feature Level 50
General Options:
Adaptive Degradation True
Discard Backfaces True
Dynamic Tessellation True
Generate Vertex Normals False
Handedness Right
Maximum LODs 6
Redraw on Window Expose True
Surface Tessellation Tolerance 92
Transparency MediumQuality
Processor
MaxClockSpeed 2201
Name Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
NumberOfCores 6
NumberOfLogicalProcessors 12
Replies (51)
Message 21 of 52
Alfred.NESWADBA
>> I can confirm this issue on AutoCAD 2022.1
You may confirm that you are seeing this in AutoCAD 2022.1, but not in AutoCAD 2021.
You can not confirm that this is an issue of AutoCAD.
As most people have success using the GFXDX12 switch to set AutoCAD back to DirectX11 the source of the issue could also be the DirectX12 driver of your graphic card. Currently we don't know if it's AutoCAD or there exist DirectX12 issues.
Have you tried the switch? (and restarted your workstation then before testing)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 22 of 52
I used DDU (Display Driver Unistaller) and reinstalled the driver. The cursor lags in DirectX12. When I switch to DirectX11 it is smooth. The graphic card is NVIDIA Quadro P620 and my driver is 471.68 (Release date 2021.8.10 )
Message 23 of 52
Alfred.NESWADBA
Good to know you got it solved!
Just one word to "current driver" ... I'm a fan of not using the most current driver, as there does not exist too many users already having experience with that driver. And the situation nowadays is very different to 20 years ago ... when a new driver might bring 20% or 50% performance raise. Today a new driver may be 0.5% faster than the previous one, and even that in just one or two software packages and not in every program.
So my goal is to find not the most current driver, but the driver that works best... and I keep this one as long as possible (also disabling it's auto-update option).
Just my 2c, - alfred -
Alfred NESWADBA
Message 24 of 52
mcc113
Observer
Observer
Fixed my issue completely have a 1050ti max q in my laptop this solved it thanks. 😄
Message 25 of 52
What an absolute legend. Thanks!
Message 26 of 52
Did you Update to the latest version of DirectX?
Message 27 of 52
Leslie.simpsonWFDCX
Community Visitor
Community Visitor
This worked easily and perfectly.
Thankyou!
Message 28 of 52
tlouis982
Community Visitor
Community Visitor
thank you very much, your solution worked for me. I use a hp 15 with NVIDIA GTX 1050 graphics card. this issue was frustrating but thanks to you sir, its resolved.
Message 29 of 52
candiceperlin
Community Visitor
Community Visitor
I cannot seem to solve my cursor lag for Autocad 2022. I work on a Mac. When I tried to type in the GX12DX1  (I’m not near the comment now so not sure I remembered this command correctly, but I plugged in what was recommended) nothing appeared in the command line. It did not register it as a command. Very frustrating.
Message 30 of 52
candiceperlin
Community Visitor
Community Visitor
I am working on a Mac and when I type GFXDX12 in the command line. Nothing registers. Am I doing something wrong. This lag is super frustrating and slows down work so much.
Message 31 of 52
carlosnayan2
Observer
Observer
Message 32 of 52
carlosnayan2
Observer
Observer
Message 33 of 52
spencerthegreat2000
Observer
Observer
This works for AutoCAD 2023 as well! I was trying to fix this for three days, thanks so much.
Message 34 of 52
palfuth
Cursor is lagging and doesn't quite keep up with anticipated location of mouse:
Command Line: CURSORTYPE
Change from: 0 to 1
Message 35 of 52
filipe_fautl
Community Visitor
Community Visitor
Perfect! Works for me!!! Thanks
Message 36 of 52
jrowley11
Community Visitor
Community Visitor
I'm experiencing a similar issue using Autocad LT 2023.
The lag doesn't happen hovering over menu bars, but once I hover over the Model and Paper space it slows down and lags for me. I've tried 3D Config and turning the Hardware Acceleration to OFF, but the issue persists.
If I do a figure 8 with the cursor you can feel the cursor droop or drag. It's so weird as it will be fine for a moment until I actually click on the paperspace.
Any suggestions would be appreciated!
Message 37 of 52
jrowley11
Community Visitor
Community Visitor
I'm on a mac as well and it doesn't recognize the command GFXDX12.
Message 38 of 52
cypooriginal
Community Visitor
Community Visitor
i got the same problem, updating drivers helped
Message 39 of 52
KM.PARK
Thanks guys
 I got problem of slow mouse cursor in autocad2022
when I saw before update autocad 2022.1
when I put 3dconfig on cm line , I could see vm : directX12
but, after updating I got DirectX 11
And there is no problem.
Message 40 of 52
stacy.tyler
I have had this same type of "laggy" issue - the cursor seems normal over menus but lags in the drawing canvas. I changed the variable "CURSORTYPE" to 1. It changes your crosshairs to look like your normal mouse pointer. It still has all the Dynamic Input features and works just like the normal crosshairs. You just don't have the "crosshair" look. However, it does seem to remove a lot of the lag at the cursor.  Using this in Civil 3D - 2022, 2023 and 2024 - without issue. I hope that helps!
