Cursor Lags
Cursor Lags
stefano7ZPLL
Message 1 of 52
Cursor Lags
stefano7ZPLL
Hi everyone,
I am using AutoCAD 2022 and I have this annoying problem, my cursor, when it is in the model space, it starts lagging. It happens only when I am in the model space. I checked online and someone said "turn off Hardware Acceleration", it worked but I needed to use the point cloud, so it is not a good choice for me.  I deactivate some feature suggested in this forum, it didn't work. I updated my graphic card and nothing.
there is a way to use the point cloud without the mouse lag? I almost try everything I read on this forum, but nothing works. Until yesterday I used 2021 and I never had this problem.
Thank You
Stefano
This is the Turner Log:
Card name: NVIDIA GeForce GTX 1050
Driver version: 27.21.14.6192
Tuning Date:
Virtual device: Dx12 (Hardware)
The card and driver meets the recommended requirement.
Display Adapters:
Intel(R) UHD Graphics 630(Primary)
Certification:
Feature Mode kFM_Advanced
Feature Mode Available 120
Hardware Available True
Hardware Recommended True
Status 5
Hardware ID 3
Hardware Feature Level 51
Software Feature Level 50
General Options:
Adaptive Degradation True
Discard Backfaces True
Dynamic Tessellation True
Generate Vertex Normals False
Handedness Right
Maximum LODs 6
Redraw on Window Expose True
Surface Tessellation Tolerance 92
Transparency MediumQuality
Processor
MaxClockSpeed 2201
Name Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz
NumberOfCores 6
NumberOfLogicalProcessors 12
Replies (51)
Message 2 of 52
pendean
Community Legend
Community Legend
While you wait... A few users are starting to post the same issue today: report it as a bug at your Autodesk Account Page: click on the ever moving ? icon on this page https://manage.autodesk.com/home/
Message 3 of 52
OysteinW
Set GFXDX12 to 0 and restart AutoCAD.
I've got the same issue here on a Nvidia Quadro RTX 3000 card.
Reverting to DirectX11 fixes the problem here.
Best regards,
Øystein Wiger
Message 4 of 52
stefano7ZPLL
Thank You @OysteinW
this was the problem: GFXDX12
Thank you very much. Finally I can use the 2022
Message 5 of 52
OysteinW
Nice 🙂
Message 6 of 52
pghcivil3d
Awesome, thanks! This is definitely an annoyance with 2022.
Rob Sinclair
Message 7 of 52
armenC888A
can you explain a bit more on how to proceed the repair
Im not sure exactly what Directx11 is ???
Message 8 of 52
armenC888A
a Solution that i just found on Youtube is :
type 3DCONFIG
and Turn off the Hardware Accelerator
it completely went away ???
Message 9 of 52
pghcivil3d
@armenC888A If you type GFXDX12 at the commandline, set the variable to 0, then restart AutoCAD the problem should go away.  You could also disable hardware acceleration.
Rob Sinclair
Message 10 of 52
Thank you so much
Message 11 of 52
Thanks that fixed it!
Message 12 of 52
thanks a lot man!
Message 13 of 52
pghcivil3d
Thanks for the tip!
Rob Sinclair
Message 14 of 52
dejan_cro
I'm trying to solve the same problem in TrueView 2022 and this is the only info I've found so far but it's not possible to type the mentioned commands and I can't find anything in the options either.
Message 15 of 52
I am having the same problem with 2022, and have set the GFXD12 to 0 and have hardware acceleration off, but the problem still persists, the cursor lags whilst only in model space. I didn't have any problems with previous versions and am using the 2022 version through the cloud so thought it was that originally. Are there any other solutions?
Message 16 of 52
pendean
Community Legend
Community Legend
@Anonymous Do you have the 2022.1 update?
Also go through this long list of things to try https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Cursor-is-slow-or-jerky-in-AutoCAD.html
Message 17 of 52
I'm assuming it is fully up to date, it's through my work and I started the job at the beginning of last month. When was the update released? I've tried the status bar and autowrap options but it didn't seem to make a difference; I like those turned on anyway. I can't do things like graphics performance / drivers as it's not my own PC. I use a Chromebook provided by the company and am accessing the cloud version of  Autocad on a Windows server.
Message 18 of 52
pendean
Community Legend
Community Legend
>>>...I use a Chromebook provided by the company and am accessing the cloud version of Autocad on a Windows server...<<<
Well there is a bit of important information we all could have used hours ago 😉
Contact your IT, there is nothing in AutoCAD to address your issue, you have an IT issue after you try these https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/pannin...
Message 19 of 52
I've been told by the IT people that the internet speed is not an issue. The cursor works fine when it's not in the black model space. There is no cursor lag or slowness when navigating around the area at the top where the tabs / command thumbnails are, it's only when I move it into the model space. That's an IT issue?
Message 20 of 52
I can confirm this issue on AutoCAD 2022.1. The cursor is laggy in the black drawing canvas, but on the other panels it is OK. It is using DirectX12. Also the cursor in the black drawing canvas in the AutoCAD 2021 is perfectly smooth and responsive.
