Cursor lagging when Dynamic Input is on
I am using AutoCAD 2017 on Windows 7. I have noticed a problem with my cursor lagging and dragging when I am actively in a task such as copy or move. This just recently started happening, and I never had the same issue in previous versions. After researching the issue I finally figured out that it only happens when Dynamic Input is turned on. So now I have to keep toggling DYNMODE on and off since I have learned to use this function and find it very useful.
I have verified that my graphic card and driver are compatible. I have turned off Hardware Acceleration, tooltips, selection preview, etc. all the other things that various blogs and forum posts have suggested. By process of elimination the culprit seems to be Dynamic Input since when it is on, the lag happens. It's like trying to threat a needle with a wet noodle! When I click out of a command it goes back to normal and moves easily across the desktop.
Can anyone offer me an explanation as to why this is happening and how to correct it?
Otto
Hello katie1994
It looks like you are looking for information related to AutoCAD not using your dedicated graphic card. Community members with similar questions found the following article(s) useful:
AutoCAD uses the wrong graphics card
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
rkmcswain
Do you have a compelling reason to have dynamic input ON? All of those things you mentioned, including DYN, all require processing power.
Do you notice the same performance drag in a new, empty drawing, as you do in a fairly large drawing?
Thanks, I had the IT department checkout your suggestions. He says all is OK. He also had me install 3 updates that I had not done as they were for different Autodesk products, one for Architecture and 2 for Recap 360. His suggestion was that there might be some small item in those updates that I might need. So I installed the updates and it seems to have solved the problem.
Curious, why wouldn't I have Dynamic Input on? What use it to me turned off?
