AutoCAD Forum
cursor / command
5 REPLIES 5
548 Views, 5 Replies
cursor / command
Newly updated to Autocad 2017.  Every entry / command ends up in the command box that opens adjacent to the cursor and then tracks with it.  How do I turn this off for good and utilize the command line box docked at the bottom of the screen?
5 REPLIES 5
john.vellek
Hi @Anonymous,
Are you referring to DYNMODE or DYNPROMPT?
If not, please send me a screen capture.
John Vellek
Dear Mr. mstanner
If am right, i guess you can toggle between your dynamic input mode by pressing F12 key......
Hope this could help you out......
Regards
Di****h. MC
john.vellek
Hi @Anonymous
I am checking back to see if my post or @Anonymous's helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
in reply to: john.vellek
I found what I was looking for under the tools menu, drafting settings, and the dynamic input tab.  I unchecked the boxes and it seems to have worked.
Thank you.
john.vellek
Hi @Anonymous,
Yes, that is another way to get to the settings I mentioned. I am glad this worked for you.
John Vellek
Forma Design Contest
