Message 1 of 11
In ACAD 2017, every time I try to change the images for my custom commands the CUI editor gives me a non-fatal JIT crash. This mean I have to unzip my CUIX files and edit the text manually, which is a bit of a PITA. How can I fix this?
"Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Object reference not set to an instance of an object"
Application does not support just-in-time (JIT) debugging. See the end of this message for details. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at Autodesk.AutoCAD.Customization.Revision..ctor(Revision rev) at Autodesk.AutoCAD.Customization.Macro..ctor(Macro macIn, MenuMacro par, Boolean preserveRevision) at Autodesk.AutoCAD.Customization.MenuMacro.duplicateMe(Macro mac) at Autodesk.AutoCAD.Customization.MainForm.buttonControlEventHandler(Object sender, ButtonControlEventArgs ea) at Autodesk.AutoCAD.Customization.ButtonControl.triggerEvent(ButtonControlAction action) at Autodesk.AutoCAD.Customization.ImageSelector.OnMouseUp(MouseEventArgs mea) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- Acdbmgd Assembly Version: 21.0.0.0 Win32 Version: 21.0.104.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL ---------------------------------------- adui21 Assembly Version: 0.0.0.0 Win32 Version: 21.0.104.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL ---------------------------------------- AdUiPalettes Assembly Version: 21.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL ---------------------------------------- WindowsBase Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll ---------------------------------------- System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- PresentationFramework Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll ---------------------------------------- PresentationCore Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll ---------------------------------------- System.Xaml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- AdApplicationFrame Assembly Version: 0.0.0.0 Win32 Version: 2015.11.1.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL ---------------------------------------- AdWindows Assembly Version: 2015.11.2.0 Win32 Version: 2015.11.2.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL ---------------------------------------- WindowsFormsIntegration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll ---------------------------------------- PresentationFramework.Aero Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- accoremgd Assembly Version: 21.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL ---------------------------------------- Acmgd Assembly Version: 21.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL ---------------------------------------- AcWindows Assembly Version: 21.0.0.0 Win32 Version: 21.0.104.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL ---------------------------------------- AcWindows.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL ---------------------------------------- AcCui Assembly Version: 21.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL ---------------------------------------- PresentationFramework-SystemXml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll ---------------------------------------- PresentationUI Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll ---------------------------------------- System.Xml.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- PresentationFramework-SystemXmlLinq Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll ---------------------------------------- PresentationFramework-SystemCore Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll ---------------------------------------- Anonymously Hosted DynamicMethods Assembly Assembly Version: 0.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll ---------------------------------------- UIAutomationTypes Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll ---------------------------------------- AcAeNet.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcAeNet.resources.DLL ---------------------------------------- AcCloudRender.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCloudRender.resources.DLL ---------------------------------------- AcCustomize.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCustomize.resources.DLL ---------------------------------------- AcDxWizard.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcDxWizard.resources.DLL ---------------------------------------- AcExportLayoutUI.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcExportLayoutUI.resources.DLL ---------------------------------------- AcInterfere.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcInterfere.resources.DLL ---------------------------------------- AcLayer.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayer.resources.DLL ---------------------------------------- AcLayerTools.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayerTools.resources.DLL ---------------------------------------- AcMrUi.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMrUi.resources.DLL ---------------------------------------- AcMultiLineUi.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMultiLineUi.resources.DLL ---------------------------------------- AcRecoverAll.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcRecoverAll.resources.DLL ---------------------------------------- AcScaleList.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcScaleList.resources.DLL ---------------------------------------- AcSeamless.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL ---------------------------------------- AcUnderlay.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcUnderlay.resources.DLL ---------------------------------------- AcViewTransitionsUi.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcViewTransitionsUi.resources.DLL ---------------------------------------- AdskConnectionPointMgd.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AdskConnectionPointMgd.resources.DLL ---------------------------------------- AcCalcUi.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCalcUi.resources.DLL ---------------------------------------- AcLayer Assembly Version: 21.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcLayer.DLL ---------------------------------------- UIAutomationProvider Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll ---------------------------------------- ClicJsInfoCenter Assembly Version: 0.0.0.0 Win32 Version: 3.1.26.0 CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/CLM/V3/MSVC14/ClicJsInfoCenter.dll ---------------------------------------- AcLivePreviewContext Assembly Version: 0.0.0.0 Win32 Version: 21.0.104.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll ---------------------------------------- AcCommandToolTips Assembly Version: 21.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCommandToolTips.DLL ---------------------------------------- AcCommandToolTips.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCommandToolTips.resources.DLL ---------------------------------------- AcCustomize Assembly Version: 21.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCustomize.DLL ---------------------------------------- System.Data Assembly Version: 4.0.0.0 Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll ---------------------------------------- System.Numerics Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll ---------------------------------------- System.Design Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll ---------------------------------------- PresentationFramework-SystemData Assembly Version: 4.0.0.0 Win32 Version: 4.6.1590.0 CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll ---------------------------------------- AcDialogToolTips Assembly Version: 21.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcDialogToolTips.DLL ---------------------------------------- AcDialogToolTips.resources Assembly Version: 0.0.0.0 Win32 Version: 21.0.52.0.0 CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcDialogToolTips.resources.DLL ---------------------------------------- ************** JIT Debugging ************** Application does not support Windows Forms just-in-time (JIT) debugging. Contact the application author for more information.
