- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
In ACAD 2017, every time I try to change the images for my custom commands the CUI editor gives me a non-fatal JIT crash. This mean I have to unzip my CUIX files and edit the text manually, which is a bit of a PITA. How can I fix this?
"Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Object reference not set to an instance of an object"
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Customization.Revision..ctor(Revision rev)
at Autodesk.AutoCAD.Customization.Macro..ctor(Macro macIn, MenuMacro par, Boolean preserveRevision)
at Autodesk.AutoCAD.Customization.MenuMacro.duplicateMe(Macro mac)
at Autodesk.AutoCAD.Customization.MainForm.buttonControlEventHandler(Object sender, ButtonControlEventArgs ea)
at Autodesk.AutoCAD.Customization.ButtonControl.triggerEvent(ButtonControlAction action)
at Autodesk.AutoCAD.Customization.ImageSelector.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
Assembly Version: 21.0.0.0
Win32 Version: 21.0.104.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL
adui21
Assembly Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL
AdUiPalettes
Win32 Version: 21.0.52.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL
WindowsBase
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Configuration
Win32 Version: 4.6.1590.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
Win32 Version: 2015.11.1.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL
AdWindows
Assembly Version: 2015.11.2.0
Win32 Version: 2015.11.2.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL
WindowsFormsIntegration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL
Acmgd
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL
AcWindows
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL
AcWindows.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL
AcCui
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL
PresentationFramework-SystemXml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationUI
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
PresentationFramework-SystemCore
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
UIAutomationTypes
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
AcAeNet.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcAeNet.resources.DLL
AcCloudRender.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcInterfere.resources.DLL
AcLayer.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayer.resources.DLL
AcLayerTools.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcScaleList.resources.DLL
AcSeamless.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL
AcUnderlay.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCalcUi.resources.DLL
AcLayer
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcLayer.DLL
UIAutomationProvider
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
ClicJsInfoCenter
Win32 Version: 3.1.26.0
CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/CLM/V3/MSVC14/ClicJsInfoCenter.dll
AcLivePreviewContext
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll
AcCommandToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCommandToolTips.DLL
AcCommandToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCommandToolTips.resources.DLL
AcCustomize
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCustomize.DLL
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Design
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
PresentationFramework-SystemData
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
AcDialogToolTips
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcDialogToolTips.DLL
AcDialogToolTips.resources
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcDialogToolTips.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
¡Resuelto! Ir a solución.
