CUI JIT Crash
Kyudos
CUI JIT Crash
Kyudos
In ACAD 2017, every time I try to change the images for my custom commands the CUI editor gives me a non-fatal JIT crash. This mean I have to unzip my CUIX files and edit the text manually, which is a bit of a PITA. How can I fix this?
"Unhandled exception has occurred in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Object reference not set to an instance of an object"
Application does not support just-in-time (JIT)
debugging. See the end of this message for details.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Autodesk.AutoCAD.Customization.Revision..ctor(Revision rev)
   at Autodesk.AutoCAD.Customization.Macro..ctor(Macro macIn, MenuMacro par, Boolean preserveRevision)
   at Autodesk.AutoCAD.Customization.MenuMacro.duplicateMe(Macro mac)
   at Autodesk.AutoCAD.Customization.MainForm.buttonControlEventHandler(Object sender, ButtonControlEventArgs ea)
   at Autodesk.AutoCAD.Customization.ButtonControl.triggerEvent(ButtonControlAction action)
   at Autodesk.AutoCAD.Customization.ImageSelector.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.6.1649.1 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
Acdbmgd
    Assembly Version: 21.0.0.0
    Win32 Version: 21.0.104.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcdbMgd.DLL
adui21
    Assembly Version: 0.0.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/adui21.DLL
AdUiPalettes
    Win32 Version: 21.0.52.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdUiPalettes.DLL
WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
PresentationFramework
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Xaml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
System.Configuration
    Win32 Version: 4.6.1590.0 built by: NETFXREL2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
AdApplicationFrame
    Win32 Version: 2015.11.1.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 2015.11.2.0
    Win32 Version: 2015.11.2.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AdWindows.DLL
WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
PresentationFramework.Aero
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
accoremgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/accoremgd.DLL
Acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/Acmgd.DLL
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.DLL
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcWindows.resources.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCui.DLL
PresentationFramework-SystemXml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
PresentationUI
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
System.Xml.Linq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
PresentationFramework-SystemXmlLinq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
PresentationFramework-SystemCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
Anonymously Hosted DynamicMethods Assembly
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/mscorlib/v4.0_4.0.0.0__b77a5c561934e089/mscorlib.dll
UIAutomationTypes
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
AcAeNet.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcAeNet.resources.DLL
AcCloudRender.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCloudRender.resources.DLL
AcCustomize.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCustomize.resources.DLL
AcDxWizard.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcDxWizard.resources.DLL
AcExportLayoutUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcExportLayoutUI.resources.DLL
AcInterfere.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcInterfere.resources.DLL
AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayer.resources.DLL
AcLayerTools.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcLayerTools.resources.DLL
AcMrUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMrUi.resources.DLL
AcMultiLineUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcMultiLineUi.resources.DLL
AcRecoverAll.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcRecoverAll.resources.DLL
AcScaleList.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcScaleList.resources.DLL
AcSeamless.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcSeamless.resources.DLL
AcUnderlay.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcUnderlay.resources.DLL
AcViewTransitionsUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcViewTransitionsUi.resources.DLL
AdskConnectionPointMgd.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AdskConnectionPointMgd.resources.DLL
AcCalcUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCalcUi.resources.DLL
AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcLayer.DLL
UIAutomationProvider
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
ClicJsInfoCenter
    Win32 Version: 3.1.26.0
    CodeBase: file:///C:/Program%20Files/Common%20Files/Autodesk%20Shared/CLM/V3/MSVC14/ClicJsInfoCenter.dll
AcLivePreviewContext
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcWindows.dll
AcCommandToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCommandToolTips.DLL
AcCommandToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcCommandToolTips.resources.DLL
AcCustomize
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcCustomize.DLL
System.Data
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
System.Numerics
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
System.Design
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
PresentationFramework-SystemData
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
AcDialogToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/AcDialogToolTips.DLL
AcDialogToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202017/en-US/AcDialogToolTips.resources.DLL
************** JIT Debugging **************
Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.287 Vistas
10 Respuestas
Respuestas (10)
Alfred.NESWADBA
>> In ACAD 2017,
The first idea I have is to make sure your AutoCAD is up-to-date. Which version/update do you have installed (command _ABOUT shows it)
Another idea is to verify if the CUI can be handled at other workstations (or when you start AutoCAD with a new Windows user account).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
Kyudos
I'm using version N.104.0.0 AutoCAD 2017 SP1.
The CUI file works OK, it seems to be the editor that doesn't - I can't change any images.
0 Me gusta
Kyudos
I'm still getting this in AutoCAD 2018 - does no one from AutoDesk have any idea why this happens? I've seen several similar problems on the forums with no real solutions...
0 Me gusta
Alfred.NESWADBA
Sounds like you are using something again in 2018 what you used in 2017 ... did you migrate settings? Did you load your own CUI's?
Where?
- alfred -
Alfred NESWADBA
0 Me gusta
Kyudos
Thanks Alfred - that has actually put me on the right track! If I unload my partial CUIX I can change the icons. But when I load my file, I can't. So obviously, it is something in my file - but how do I find out what? As far as I can tell, everything else is working fine (i.e., all my commands work)
I guess I was hoping that, knowing this happens immediately after I click an icon in the CUI icon grid for a command, and given this stack trace:
I was hoping someone at AutoDesk might be able to give me some pointers....
I wonder if it makes a difference that MY icons are in a resource DLL?
0 Me gusta
Alfred.NESWADBA
Create a new CUIX and use the transfer option to move parts of your menu from the old file to the new file and see when the new file stops working.
Sorry that I'm not from Autodesk, but also they might need the CUIX, just guessing what is wrong with your file wihout seeing it is impossible.
Could be, if the DLL is defect or not found by AutoCAD.
- alfred -
Alfred NESWADBA
0 Me gusta
Kyudos
Hmmm...good idea, but I get the same error when I try to move anything to a new CUIX using the Transfer tab...
0 Me gusta
Kyudos
Solución aceptada
With a hint from the stack trace and comparing with the contents of a new CUIX file I found that most of my entries in the internal CUI files were missing the <ModifiedRev> tag.
AutoDesk people take note please! Just add it if it's missing, no need for an exception :cara_guiñando_un_ojo:
0 Me gusta
Kyudos
Just to point a out to AutoDesk - this is still a problem with legacy CUI files in AutoCAD 2020.
0 Me gusta
TomBeauford
Still just as buggy in 2021
Never understand why AutoCAD can backup drawing files so well and have no method whatsoever for CUIX files.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
