Creating Custom Font
I need to create a custom font from polyline profiles. Is there anyway to save the polylines to create a custom font?
Ed__Jobe
To create a font, you first have to convert the symbols to shapes. Use the Express Tools Make Shape (MKSHAPE) command. This saves the symbols to a *.shp file. When you are done, you have to compile the shape file using the COMPILE command. This saves it as a *.shx file.
Ed
How to post your code.
Alfred.NESWADBA
start here to find how to create SHP files and to compile then to be used as fonts (or symbols) >>>click<<<.
The ExpressTools might help too with the command MKSHAPE (>>>details<<<)
HTH, - alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Ed__Jobe
This topic also explains the format for shp text files. You can use the Express Tools DUMPSHX to decompile an shx file to a shp file to see how it was created or use it as a template for your shp file.
Ed
