UNIFORMITY When Importing/Pasting Excel Sheets
Hey guys,
Wanted to get a few opinions on this if possible.
I am currently working on a Plan Set for a small municipality.  My boss has asked that I create the Plan Set in AutoCAD and include all of my Excel tables , maps, etc by using the program.
Uniformity is key so I am trying to figure out the best way to create a uniform Plan Set which includes all of the data I mentioned above (i.e. same height, width, etc..).  My excel Sheets are all uniform but when I import into AutoCAD the sizing is different on each table.  Any thoughts on how to get uniformity?  Currently using "Paste Special" and then trying to re-size.  Maybe I should use a different "Paste" function?
Any help is greatly appreciated.
Thanks!
Chris
imadHabash
i'm always do it as :
  • open the excel table via Microsoft Excel and mark (select ) the cells that you need .
  • Ctrl+C to notice a dimmed rectangle .
  • keep it opened and go to AutoCAD  Edit > Paste special (see below image )
Hope it's work ...
Imad Habash
Thanks for the reply,  that's not exactly what I'm looking for but thanks.
imadHabash
i understand what you're asking for ... what i mean in my previous post is that you will always get the right size when you insert it if you follow the previous steps. also you have to know that number and size of rows and columns in a table will affect the size of table when inserted.
Imad Habash
yes I understand all of that thanks.
john.vellek
Hi @Anonymous,
My preferred way to do this is to create a datalink for each worksheet. Then I insert a table based upon the datalink and make sure to keep all formatting done by Excel. I like to place my tables in paperspace.
Does this workflow sound plausible?  If you have some sample files I am happy to mock this up for you.
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post or Imad's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
