Creating a Keynote List based on Keynotes Used in a drawing...
jim3thornton
jim3thornton
In the past, I had worked on a project that all I had to do was provide the correct keynotes and then type in a command that populated the Keynote List.
Is this a feature that is still available with AutoCAD?  And if so what is the command?
I am also aware that one of the autocad platforms has a keynote database.
imadHabash
if i understand your need right,and if these keynotes are blocks you can by DATAEXTRACTION command do a schedule list with all of selected blocks.
Imad Habash
TerryDotson
Autodesk's Architectural Desktop may have that.  If you wish to remain on your existing AutoCAD, take a look at the Keynote functionality in ToolPac.
jim3thornton
I have file that includes these blocks, but I do not see the associated .dxe file ...
The file has an entire list of blocks (100-900) when you select insert ...
There is also a table that contains only a few of the categories ...
I had updated it once with a command but have since forgotten that command
Any ideas ...
