Inserting a row in a table
RalphBrown99
Message 1 of 12
RalphBrown99
Hi:
I have a table in AutoCAD that was imported from Excel. Now I have to edit the table and I have to add a row however if I highlight the cell that is going to have a new row below the software does not allowing me. As soon the cell is selected I do right click and the option Rows>Insert below is grayed out. Actually the options in the panels Rows and Columns (in the Table Cell contextual menu) are grayed out as well.
How can I add a row just below this or any other cell.
I am attaching the CAD file. The cell that says "CONTENTS TO DUPLICATE" is the the one I want with an extra arrow below.
Thanks in advance
Rafael Moreno
Just in case: I am wondering to add a row as a copy of the row where my highlighted cell is sitting. So in the case of the file the new row is going to have the same cell with "CONTENTS TO DUPLICATE" as a text. Cheers
Replies (11)
Message 2 of 12
jim3thornton
Rafeal,
Do you copy the area in the excel spread sheet and then paste special, selecting autocad entities into your drawing?
I use this method for sheet indexes.
You type DATALINK and redefine the cells that you have selected originally in excel.
or in the future select additional empty cells and then when you update your table you will not have to redefine your boundaries
Message 3 of 12
RalphBrown99
Hi Jim:
I am not copying pasting from excel. The CAD file that I am editing with the spreadsheet inside has lost the connection with the original excel file. So basically I can use only CAD commands to edit the table.
Thanks for your help
Rafael
Message 4 of 12
jim3thornton
Have you tried to right click on the table ...
there may be an option to select "add row"
Message 5 of 12
RalphBrown99
HI Jim:
I selected the table and I got different options according if I select the full table or the cell.
If I select the full table:
Right click>Rows>(Two options, insert above or insert below) They add a row either at the top or the bottom of the table not in the location I need
If I select the cell
Right click>Rows>(The same two options insert above or insert below) They are grey out. Besides the Panels Rows and Columns are greyed out as well
So it is the situation I have. Just in case you need more details, please let me know
Rafael
Message 6 of 12
have you tried to see if the cells are locked.
Message 7 of 12
john.vellek
Hi @RalphBrown99,
Does the original Excel file still exist? This is the file that the Datalink is looking for:
N:\Client\Teck_Resources_Ltd\Quebrada Blanca\02_DATA\Tabular\Process\PFD Mass Balance.xlsx
If it does, you can select your table in AutoCAD, rt-click and Select Data Links>Edit Data Link:PFD Mass Balance. This would re-estabilsh the connection.
If the Excel file no longer exists, then select a cell in the table, rt-click and select Datalink, select the PDF Mass Balance , rt-click and then select Delete.
Now you should be able to select a cell, rt-click and go to Rows and then FINALLY insert.
John Vellek
Message 8 of 12
john.vellek
Hi @RalphBrown99
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 9 of 12
RalphBrown99
Hi:
Sorry for the long replay. I am sorry but my PC was broken.
Sure the cell is unlocked
Thanks in advance
Rafael
Message 10 of 12
RalphBrown99
Hi John:
As I promised, I am replaying you in regards the excel file -add row problem-. There has been a lot of ex-changes and now everything is confused. Go back to the beginning, I can not add a row in the spread sheet that I have in AutoCAD. The original file in excel is gone and actually I do not need it any more due the edits that I am doing now in AutoCAD. I check your video  and I confuse you but I want to focus in the purpose to add a row in the table. Do you need the CAD file
Thanks in advance
Rafael
Message 11 of 12
john.vellek
Hi @RalphBrown99,
I have attached a Screencast that shows how I went through this process. First you will notice that I ran Audit and Purge as your file had quite a few errors in it.
Next I went through the steps outlined previously. I did show how to also "Unmerge" the first cell in case that helps you.
John Vellek
Message 12 of 12
RalphBrown99
Hi John:
First of all, soooorry for the long replay. Second, thanks for the video. Finally I could add a row in the part of the table that I need. Your video with the mouse highlighting either right or left click is super-useful.
I feel that the key part is highlight the cell>left click>Data Links>Detach Data Link
It makes available the command highlight the cell>left click>Rows>Insert Below
The first command make my Rows and Panels available so it is possible to do the edits I need.
I hope to keep contact
Rafael
