AutoCAD Forum
Created PDF's have thick black lines
5 REPLIES 5
1906 Views, 5 Replies
Hi guys I got a problem since upgrading to windows 10. When i create a PDF from a DWG the lines are very thick. I am able to view older PDF's which are still fine but cannot make new ones without the thick dark horrible lines Attached is an example of the problem PDF's Can anyone help me Thanks Simon
5 REPLIES 5
pendean
Nothing attached.
Win10 has nothing to do with PDF output from AutoCAD: is it just your PDF viewer that needs adjusting for display, or do you need to use a different Plot Style Table or LWEIGHT settings when you plot from AutoCAD?
What is your AutoCAD version?
in reply to: pendean
I have AutoCad 2015. I am not that great with CAD and PDF setting etc but the problem only just started after going to windows 10. Windows 10 seems to have its own viewer so i had to set PDF as default again oops i forgot to attach, here it is Thanks for the fast response by the way
Seem the attachment wont work, i browse and then add attachment but it doesnt seem to show up 😞 i am such a noob
Here is the attachment
I seem to have solved the problem, you were right above when you mentioned line weight. For some reason i was drawing with thicker lines and did not notice Thanks for your help
AutoCAD Inside the Factory
