Do you know of a best practice for autodesk license management software.
License management for multiple servers and mulitple software products.
License Statistics is one.
Autodesk has the License manager LMTOOLS Utility
any others that might be worth looking at?
What is the best pratices for managing Network licenses and products?
Hello
If you are looking for a software to analyse your FlexLM license Usage, JTB has the right tools :
http://jtbworld.com/jtb-flexreport
There is even a JTB FlexReport LT (free software) version with limited features ...
Regards, Patrice
Patrice BRAUD
You can try searching the Autodesk app store. https://apps.autodesk.com/en
Here's a tool I found which sounds close to what you are looking for.
https://apps.autodesk.com/ACD/en/Detail/Index?id=2416537186835607940&appLang=en&os=Win32_64
Can you purchase several suites and then break up the suite and install say, AutoCAD on 50 computers and then install say, Revit on 25 computers without installing the whole suite on not of the computers. And yes, i do realize the suite license will be used ever time Revit opens and every time AutoCAD is opened. But will a suite license be used for each if I installed AutoCAD (out of a suite) on one computer and install Revit (out of a suite) on the same computer? Any thoughts.
