AutoCAD Forum
create smooth curved solid 3D in AUTOCAD
20 REPLIES 20
Message 1 of 21
6996 Views, 20 Replies
I have the problem in AUTOCAD how to create curve in 3D to make a solid 3D curved transition
20 REPLIES 20
Message 21 of 21
elshawadfy
Hi @Anonymous,
(And happy Eed 🙂 )
If I understood correctly, you want the result to be a "Solid" not a "Surface"..
You can follow the steps I've shown, then:
1- Copy or move the newly created part away to be able to see both ends..
2- Use "Patch" command to close both ends:
        - Patch > ch (for chain) > Select the opening border.. > enter > enter..
        - Repeat for the second end
3- "Union" all three surfaces, accept the warning and proceed..
4- Use the command "CONVTOSOLID" to convert the result to solid..
Regards..
Forma Design Contest
AutoCAD Beta
