I have the problem in AUTOCAD how to create curve in 3D to make a solid 3D curved transition
Solved by elshawadfy. Go to Solution.
Solved by Michiel.Valcke. Go to Solution.
Solved by SEANT61. Go to Solution.
Hi @Anonymous,
(And happy Eed 🙂 )
If I understood correctly, you want the result to be a "Solid" not a "Surface"..
You can follow the steps I've shown, then:
1- Copy or move the newly created part away to be able to see both ends..
2- Use "Patch" command to close both ends:
- Patch > ch (for chain) > Select the opening border.. > enter > enter..
- Repeat for the second end
3- "Union" all three surfaces, accept the warning and proceed..
4- Use the command "CONVTOSOLID" to convert the result to solid..
Regards..
