I was having trouble with creating a solid object/surface between the red lines. Can someone help me with this?
Solved by Patchy. Go to Solution.
>> I was having trouble with creating a solid object/surface between the red lines. <<
would you please describe more your trouble ?
Imad Habash
Between de lines must be a surface with a curve, but I dont no wich command to choose/use
