AutoCAD Forum
Create complex object problem
3 REPLIES 3
jumeletremco
384 Views, 3 Replies
Knipsel.JPGI was having trouble with creating a solid object/surface between the red lines. Can someone help me with this?
3 REPLIES 3
imadHabash
in reply to: jumeletremco
>> I was having trouble with creating a solid object/surface between the red lines. <<
would you please describe more your trouble ?
Imad Habash
jumeletremco
in reply to: imadHabash
Between de lines must be a surface with a curve, but I dont no wich command to choose/use2018-04-09.png
Patchy
Loft 2 surfaces, using the yellow arc for GUIDE path
Forma Design Contest
AutoCAD Beta
