AutoCAD Forum
Copy/ Paste multiple drawings ignore AEC objects
28 REPLIES 28
Message 1 of 29
pixelarch
8287 Views, 28 Replies
Dear All,
The problems : we got the big size file (file A), we fix it then we copy/ paste information (e.g. texts) from the other bad file (file B). File A becomes big size again although texts were copied is simple.
Question : How the best to copy these texts?
Thanks.
28 REPLIES 28
Message 2 of 29
maxim_k
in reply to: pixelarch
Try to WBLOCK text from file B. This will create file C containing only text you want to copy from B to A. Then insert exploded file C into file B.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 29
pixelarch
in reply to: maxim_k
Thanks. Any way else?
Message 4 of 29
Alfred.NESWADBA
if you open the "bad file" ... do you get proxy-warnings? (assuming you have set the variable PROXYNOTICE to 1)
If so then please upload a screenshot with that dialog so we can see what applications were involved in creating/modifying that dwg.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Message 5 of 29
pixelarch
in reply to: Alfred.NESWADBA
No proxy warning, alfred.
Message 6 of 29
pendean
if you know there are AEC objects, use -EXPORTTOAUTOCAD command (there is a dash in the command name) to convert them first. Aim for a low format DWG file works best.
Message 7 of 29
pixelarch
in reply to: pendean
-AECTOACAD just works with ACAD 2011. If run AECTOCAD in 2013 platform the file become bigger a little, not smaller.
Message 8 of 29
pendean
It gets bigger because the AEC objects are exploded into core AutoCAD formats. AEC objects are your problem, time to fix them.
And that's not the command I wrote, re-read it: you are referencing a PGP mask.
May I ask what is this obsession with file size (looking at your other post): how big are we talking about (before and after)?
Message 9 of 29
pixelarch
We are working on big projects, working file is around 15 MB. The sheet file xref over 20 working file. When we bind it, final file is over 150 MB in size.
Now, i can reduce 15MB to 200KB but after that member copy elements from old drawing, it become bigger again although they just copy some text. I try to stop it.
Generally, when we copy/ paste elements from heavy file (it takes long time around 5minutes to process) to clean file. Then clean file get bigger immediately.
But i dont know why its around 15MB. Pls see the link http://www.mediafire.com/?41zw6ezextz5vhb
Message 10 of 29
I have experienced the issue that you are describing and this is due to the presence of DGN linetypes which will be caried to another drawing if someone copy and paste objects from that file. I use batch tool to clear my project files to free of DGN linetypes and after that it works as expected. I have attached your file back after DGN linetype purged.
Message 11 of 29
pendean
The fix must be applied to ALL your files: fixing only one file is not a final solution as you will repeat the problem over and over again.
Explore purchasing a third party tool called SUPERPURGE to fix all of your files.
Message 12 of 29
pixelarch
How can you do that?
Message 13 of 29
pixelarch
I knew it pendean. I tried to help whole teams fix this but too many people working on over 1000 files. I want to fix this at one time. That is the reason i create another topic to create DXFOUT script http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/DXFOUT-script/td-p/4300929
Then i can use scriptpro to fix this after everybody leave office.
Let think about SUPERPURGE
Message 14 of 29
Try with free batch tools available from http://www.cadmanagertools.com
It is compatible with AutoCAD 2012 only.
Message 15 of 29
pixelarch
I used 2013. No choice?
Message 16 of 29
If you have the version of 2012 AutoCAD or Civil 3D then use that to purge the linetypes then continue  with 2013 until the tool is available for 2013 & 2014
Message 17 of 29
pendean
http://manusoft.com/software/superpurge.html has no version limitations AFAIK.
Message 18 of 29
Is it free as the tool which I mentioned.
Message 19 of 29
pixelarch
SPURGE works slowly?
Message 20 of 29
pixelarch
I will try it later. My company upgraded to 2013 already.
Forma Design Contest
