Dear All,
The problems : we got the big size file (file A), we fix it then we copy/ paste information (e.g. texts) from the other bad file (file B). File A becomes big size again although texts were copied is simple.
Question : How the best to copy these texts?
Thanks.
Solved by pixelarch. Go to Solution.
Solved by maxim_k. Go to Solution.
Try to WBLOCK text from file B. This will create file C containing only text you want to copy from B to A. Then insert exploded file C into file B.
Maxim
if you open the "bad file" ... do you get proxy-warnings? (assuming you have set the variable PROXYNOTICE to 1)
If so then please upload a screenshot with that dialog so we can see what applications were involved in creating/modifying that dwg.
- alfred -
-AECTOACAD just works with ACAD 2011. If run AECTOCAD in 2013 platform the file become bigger a little, not smaller.
We are working on big projects, working file is around 15 MB. The sheet file xref over 20 working file. When we bind it, final file is over 150 MB in size.
Now, i can reduce 15MB to 200KB but after that member copy elements from old drawing, it become bigger again although they just copy some text. I try to stop it.
Generally, when we copy/ paste elements from heavy file (it takes long time around 5minutes to process) to clean file. Then clean file get bigger immediately.
But i dont know why its around 15MB. Pls see the link http://www.mediafire.com/?41zw6ezextz5vhb
I have experienced the issue that you are describing and this is due to the presence of DGN linetypes which will be caried to another drawing if someone copy and paste objects from that file. I use batch tool to clear my project files to free of DGN linetypes and after that it works as expected. I have attached your file back after DGN linetype purged.
I knew it pendean. I tried to help whole teams fix this but too many people working on over 1000 files. I want to fix this at one time. That is the reason i create another topic to create DXFOUT script http://forums.autodesk.com/t5/AutoCAD-2013-2014-DWG-Format/DXFOUT-script/td-p/4300929
Then i can use scriptpro to fix this after everybody leave office.
Let think about SUPERPURGE
Try with free batch tools available from http://www.cadmanagertools.com
It is compatible with AutoCAD 2012 only.
If you have the version of 2012 AutoCAD or Civil 3D then use that to purge the linetypes then continue with 2013 until the tool is available for 2013 & 2014
