thank you for the video, but sorry to say, it does not answer any questions of the above ones (e.g. I can't see if there are layers frozen, which version of AutoCAD you are using, what object types you have (it could be a block and a block with that name, but different block definition could already exist in the destination dwg) ... and much more.
Please answer my questions and share a drawing so we can try to reproduce the issue and so give valid suggestions (which would result in much faster solution for you compared to start guessing for hours now).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
