How to save printer settings in pc3 file programmatically in C #
I work with pc3 files in the C # programming language using the PiaNO library (https://github.com/phusband/PiaNO). It allows you to read and modify existing pc3 printer configuration files. How can I create a new pc3 file programmatically in C #?
thanks
Alfred.NESWADBA
You are using a library that is not from Autodesk, I would ask in the GitHub place for PiaNO.
This here is not a developer forum, the one for AutoCAD dotNET develepment would be >>>there<<<, but I guess also not for questions about 3rd party products like that.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Thanks.
