AutoCAD Forum
Copy/Mirror/Array Commands Freeze
7 REPLIES 7
Message 1 of 8
2040 Views, 7 Replies
We have installed the latest version of Autocad 2015.  The problem is everytime we use the Copy / Mirror or Array Commands, the system will freeze for 5 seconds.  We did not have this issue on previous versions 2014 or 2012.  We have since upgraded the graphics cards to 2GB Nvidia cards.
Running Windows 7, 64bit
Intel i7-2600 3.40GHz
16 GB ram
Anybody else experiencing these problems or know of a solution.
7 REPLIES 7
Message 2 of 8
rkmcswain
Just those 3 commands?
Freeze right after initiating the command or after you select the objects or?
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 8
in reply to: rkmcswain
These are the only 3 commands that I have found that do this.  It happens at the end of the command.  When you are basically pressing "enter".
I have played around with some settings and it seems that the "Linesmoothing" feature is causing the issues.  When we turn this off, the hesitation and lagging stops.
Message 4 of 8
rkmcswain
You might install SP1 for AutoCAD 2015 and make sure your NVIDIA drivers are the latest.
Message 5 of 8
Shawn_Niles
If turning LINESMOOTHING off resolves this, that is probably the easiest solution. SP1 may help, and also going back to DX 9 may help as well:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Shawn Niles
Message 6 of 8
can you try to erase all objects on the drawing. make it blank. and save it on different name. check the file size....
Message 7 of 8
I m also experincing this kind of problem. install sp1 sp2, dgn purge hotfix, doesnt help.
I try to start over the drawing from the beginning which is take so much time....but after sometimes the problem appear again.
My computer spec. i7 3.2mhz, 16gb ram, nvidia quadro graphic card ssd hard drive.
Please any one can help ....
Thankyou...
Message 8 of 8
I'm having the same issue. Did you find a solution?
Forma Design Contest
