In acad 2016 when using the copy command, the object to be copied is not dragged across the screen. It does happen when using the express tools MOCORO command. Is there a command where the copy and drag function is available. The same happens when I try and insert a block into a drawing, the block image does not appear as a movable item which can make it difficult to position the block
Solved by rkmcswain. Go to Solution.
welcome @Anonymous.autodesk.com!
>> when using the copy command, [...] It does happen when using the express tools MOCORO command
Well, is it now the COPY command or the MOCORO command?
That can happen when the block is (compared to the current view) very small or very large.
A global tip without know details now: how is sysvar DRAGMODE is configured, is it set to "Auto" which is the default? (>>>details<<<).
- alfred -
