AutoCAD Forum
Copy and Drag Command
3 REPLIES 3
1682 Views, 3 Replies
In acad 2016 when using the copy command, the object to be copied is not dragged across the screen. It does happen when using the express tools MOCORO command. Is there a command where the copy and drag function is available. The same happens when I try and insert a block into a drawing, the block image does not appear as a movable item which can make it difficult to position the block
3 REPLIES 3
Alfred.NESWADBA
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
>> when using the copy command, [...] It does happen when using the express tools MOCORO command
Well, is it now the COPY command or the MOCORO command?
That can happen when the block is (compared to the current view) very small or very large.
A global tip without know details now: how is sysvar DRAGMODE is configured, is it set to "Auto" which is the default? (>>>details<<<).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
- alfred -
Alfred NESWADBA
rkmcswain
rkmcswain
Is DRAGMODE set to Auto ?
in reply to: Alfred.NESWADBA
Dragmode was set to ON, changed it to AUTO and now drag is enabled with copy and block insert commands. Thanks for your help
AutoCAD Inside the Factory
