Can you somebody tell me how can I change my coordinate value from scientific to Meter, now I am getting a value "X = 473533.4249204 Y = 2.7807191E+06 Z = 0.0000000" how can get Y Value same as X.
Regards
Solved by Alfred.NESWADBA. Go to Solution.
coordinate system has three axes, X, Y, and Z.
"X = 473533.4249204 Y = 2.7807191E+06 Z = 0.0000000" this is your 2d drawing working area, Z always '0'
watch this video, if you move all drawing near to icon or move icon to drawing X & Y will change
how can get Y Value same as X?
Command Line enter same Drawing coordinate you need
Please clarify you question <<<<<Can you somebody tell me how can I change my coordinate value from scientific to Meter>>>>>>
Hint : Change Scale Factors:
Inches to Millimeters = 25.4
Millimeters to Inches = 0.0393701
Inches to Centimeters = 2.54
Centimeters to Inches = 0.393701
Feet to Millimeters = 304.8
Millimeters to Feet = 0.00328084
Feet to Centimeters = 30.48
Centimeters to Feet = 0.0328084
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
In the UNITS command/dialog specify less digits (precision) to be displayed for coordinates.
The more digits you have the earlier AutoCAD changes the display to the ...E00 format when you are at high (geographic) coordinates.
- alfred -
