Converting IGS to DWG
duffeyc34
Message 1 of 15
duffeyc34
Can anyone help me convert an igs to a dwg file. files are attached. Currently using AutoCAD 2015
Replies (14)
Message 2 of 15
dmfrazier
Are you unable to do this with your seat of AutoCAD 2015?
Can you not request this from the author of the IGS files?
Message 3 of 15
Todd_Rogers
Type in IGESIMPORT.
Todd Rogers
Civil Administration
Message 4 of 15
pendean
Community Legend
Community Legend
The ZiP files appear to be corrupt, they don't want to unzip. Is that your actual problem?
Message 5 of 15
dmfrazier
They unZIPped fine for me.
Message 6 of 15
pendean
Community Legend
Community Legend
Weird, Win7 keeps reporting an error with both files (which I assume are one and the same content).
Message 7 of 15
duffeyc34
The author of the files is using SolidWorks. I received this screen shot as available ways to save the file.
Message 8 of 15
duffeyc34
Yes one of my problems is extracting the files, gives me "Error 0x80004005"
Message 9 of 15
duffeyc34
For some reason I cannot unzip, can you send me the unzipped file?
Christopher Duffey
Virtual Design Coordinator
[cid:[email protected]]
McDonald Electrical Corp
72 Sharp St, Unit C-8 | Hingham, MA 02043
P: 339-205-2236 | C: 781-724-2911
[email protected]
Message 10 of 15
duffeyc34
Im having trouble unzipping the file, any chance you could send me the .dwg file if you are capable of using the igesimport command?
Christopher Duffey
[email protected]
Message 11 of 15
dmfrazier
I tried to attach a ZIP with the DWG export files, but the site objects that it is too large (5MB limit).  The two DWG files are about 18MB apiece, and the ZIP file is about 27MB.
Message 12 of 15
pendean
Community Legend
Community Legend
You need new ZIP files, or better yet, ask them to share files with you through a service like DROPBOX.
Message 13 of 15
Patchy
Unzipped fine on 1 pc, another died.
But I separated them, let's see if they work.
Message 14 of 15
TheCADWhisperer
What version of SolidWorks?
Ask them for STEP *.stp or the native SolidWorks *.sldprt and *.sldasm (if using SolidWorks v2015 or earlier).
Download your dwg files from A360 Drive -
http://a360.co/1UCL5Hg
http://a360.co/1IGj7VG
The properties of the files indicated SolidWorks 2013.
AutoCAD 2015 and 2016 will open these native SolidWorks assembly and part files without conversion to STEP or IGES.
Instruct them to
Place the assembly and part files into a single folder>
Right click on the folder using Windows Explorer and select Send to Compressed (zipped) folder.
No neutral format conversion is needed.
Message 15 of 15
dmfrazier
Or simply ask them to ZIP the files with a different ZIP utility (maybe?).
Or (maybe?) the OP could try a different ZIP utility to unzip.  (I used 7-Zip, successfully. The IGS files are good, and import into AutoCAD just fine.)
