Message 1 of 15
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Can anyone help me convert an igs to a dwg file. files are attached. Currently using AutoCAD 2015
The author of the files is using SolidWorks. I received this screen shot as available ways to save the file.
I tried to attach a ZIP with the DWG export files, but the site objects that it is too large (5MB limit). The two DWG files are about 18MB apiece, and the ZIP file is about 27MB.
Unzipped fine on 1 pc, another died.
But I separated them, let's see if they work.
@duffeyc34 wrote:The author of the files is using SolidWorks. I received this screen shot as available ways to save the file.
What version of SolidWorks?
Ask them for STEP *.stp or the native SolidWorks *.sldprt and *.sldasm (if using SolidWorks v2015 or earlier).
Download your dwg files from A360 Drive -
The properties of the files indicated SolidWorks 2013.
AutoCAD 2015 and 2016 will open these native SolidWorks assembly and part files without conversion to STEP or IGES.
Instruct them to
Place the assembly and part files into a single folder>
Right click on the folder using Windows Explorer and select Send to Compressed (zipped) folder.
No neutral format conversion is needed.
Or simply ask them to ZIP the files with a different ZIP utility (maybe?).
Or (maybe?) the OP could try a different ZIP utility to unzip. (I used 7-Zip, successfully. The IGS files are good, and import into AutoCAD just fine.)
