Converting .dwf file to .stl
Message 1 of 22
hey everyone i'm wondering what is the easiest way to convert this .dwg file I have to .stl? the exporting option doesn't seem to be working within AutoCad i'm not sure why :-S Advice?
Replies (21)
Message 2 of 22
In AutoCAD type EXPORT, the STL option will appear in the FILES OF TYPE.
Message 3 of 22
Patchy
Not with .DWF you can't
Message 4 of 22
Patchy
A lot of CAN'T today.
Hope you're not mad
Message 5 of 22
The OP is confusing, its titled DWF but DWG is in the actual question.
Is the original question for exporting from DWF or DWG to STL?
Message 6 of 22
Patchy
So far I see:
.obj to STL
.dwg to .stl
.dwf to stl
and I don't know anything about using Mac as OP does.
Message 7 of 22
ampster40
Message 8 of 22
ya really just looking for this file to be converted or exported to .stl
it was DWG not DXF.  Patchy could u try that for me, when I tried adjusting thickness i had no success
Message 9 of 22
dwg, this file attached..sorry for the confusion
Message 10 of 22
ampster40
Using your file in Acad 2016 when attempting to export to .stl, Acad reports this; "Command: _EXPORT Select solids or watertight meshes: all 5261 found Select solids or watertight meshes: Selected objects must be solids or watertight meshes. 5261 objects removed from the selection set." So, something is wrong with the wireframe/mesh objects in this file. It will not export to .stl in this current condition. HTH
Message 11 of 22
Patchy
See if you can STLOUT using this .dwg
Message 12 of 22
Supplied file does not have any solids or meshes.
Message 13 of 22
Patchy, I get a bunch of the below errors when using your DWG.
Modeling Operation Error:
Inconsistent edge-face relationships.
The Boolean operation on solid and/or surface bodies failed.
Message 14 of 22
Patchy
Doesn't sound right.
I listed them:
Message 15 of 22
Patchy
Could be 2008 I'm using?
Time to get new versions, I'm broke.
Maybe Autodesk has something free 3 years for Expert Elite Smiley Very Happy
Message 16 of 22
i got the same thing
Message 17 of 22
I'm testing with AutoCAD 2016, with no luck on either DWG supplied.
Message 18 of 22
original file was .obj but not viewable on autocad so I converted to .dfx to view in autocad
Message 19 of 22
Then the issue is probably with the conversion from OBJ to DXF.
What application did you use?
Message 20 of 22
i used meshlab software
