Converting Autocad file to Solidworks file
I just got this file from the engineers that are doing a land project.  I have tried to convert it to a 3d solidworks file and I have no clue what I am doing, if anyone could help that would be appreciated.
Alfred.NESWADBA
IMHO Solidworks can read DWG and DXF, just send the file.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
I tried, and got no where.  I attached the file, maybe there is something I am not seeing
Alfred.NESWADBA
What I see in your file:
  • it shows 355 errors (using command _AUDIT in AutoCAD 2020.1.2).
  • it also contains proxy objects from Civil 3D
  • it has very high coordinates (that could be an issue for Solidworks, don't know
  • objects are far away to each other, so zoom extents makes objects smaller than a pixel, also in Solidworks
Please find attached a dwg-file that is
  • repaired by command _AUDIT
  • killed proxy objects (also the cogo points inside the modelspace)
  • erase objects that are far away but without a meaning (6 lines and 1 hatch)
  • (coordinates are not changed)
Hope that works better 😉
- alfred -
Alfred NESWADBA
Wow, that was really nice of you man.  You helped a kid out of a jam big time.  Thanks a million.
    I'm an Architect and i had a similar concern while converting autocad file to solidworks file. i got help from bimdex people, their resouce helped my with my other conversions as well. make sure to check their page bimdex. have a great day
