Changing Cordinates
Changing Cordinates
yogeshnairvarkala
Changing Cordinates
yogeshnairvarkala
hi friends..
I am looking for a help ..am having a drawing with cordinates ..these cordintes was generated with lisp..when i move those cordintes it will automatically change..i want to copy the drawing in the same layout without changing the cordiantes..means i want show old and new in same layout without changing cordiantes..is there any way??
imadHabash
it seems that you're treating with Fields attributes or text values ... you can control this issue by FIELDEVAL (System Variable) , try it and see if any changes ?  >> Click <<
Imad Habash
Alfred.NESWADBA
Not sure to understand you well.
Your coordinates (I assume you mean the leaders with E/N/FRL/IL) ... are they all played in modelspace and in the same dwg-file?
If they are in different dwg-files you can use command _XREF to insert/reference one coordinate file into the other and move the XRef.
If they are in the same dwg-file and inside a modelspace you might create 2 viewports in the layout, one showing geometry at lower coordinates and the other viewport with the higher coordinates ... then move the viewport so that the geometry overlaps in the way you like (if my understanding here is correct).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
yogeshnairvarkala
tks done with it
imadHabash
just to check ... does it resolved ?
Imad Habash
yogeshnairvarkala
Yes i do i changed the value 31 to 1.. its solved tks buddy
cadffm
You should read the help "again"
Sebastian
