>> i want to copy the drawing in the same layout without
>> changing the cordiantes
Not sure to understand you well.
Your coordinates (I assume you mean the leaders with E/N/FRL/IL) ... are they all played in modelspace and in the same dwg-file?
If they are in different dwg-files you can use command _XREF to insert/reference one coordinate file into the other and move the XRef.
If they are in the same dwg-file and inside a modelspace you might create 2 viewports in the layout, one showing geometry at lower coordinates and the other viewport with the higher coordinates ... then move the viewport so that the geometry overlaps in the way you like (if my understanding here is correct).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
